TwinTurbo.NET: Nissan 300ZX forum - Extreme, but 30psi rear and 45 psi front
Subject Extreme, but 30psi rear and 45 psi front
Posted by escturbo on February 15, 2008 at 12:44 PM
  This message has been viewed 48 times.
In Reply To what tire pressure should I inflate these tires? posted by rx7 to z on February 15, 2008 at 09:26 AM
Message I've found that much less pressure in the rear tires helps them to wear more uniformly, instead of mostly in the center. The fronts tend to wear the corners faster, so more psi helps the wear spread to the center. This is on 100% stock suspension w/ stock alignment settings. The rear Fusion Zri tires lasted ~20k and the fronts are still good at 25k at those psi settings w/ heavy street use.
